Is There Any Way To Dial Number, Change Destination, And Play Mp3 With
I have seem people modify the wires behind the navigation but I like to know if there is other way to go around it so we can watch DVD, dial number, change destination, and play mp3 without stoping the car?
Also trying to find out if we can custom the driver seat so when you enter and exit the car it will move back so it's easier to step out the car. Merceses E320 hsa this feature but so far IS350 only has the wheel that moves away.
ccjw.
Having found any other fix to watch DVDs. There is a "soft fix" so that you can input Destination information while driving. It also allows you to use the phone. Not sure about the MP3 part as haven't tested that with the soft fix.
Soft fix is: Go to menu screen, select volume, tap the screen in the top LHS then bottom LHS, then again top LHS and bottom LHS of the screen.
This brings up a service screen. Press and hold the Override setting for about 5 seconds and setting will change. Return to previous screens. This will last till you stop the car.
