I just received my 5mm LEDS for my 1996 Lexus ES300, which fit right into the green bulb housings. Anyway I wanted to know how can I find the negative and positive points on the bulb sockets? If I use a voltemeter how can I power the cluster out of the car to find the negative and positive points of the 8 blub sockets. Any help would be greatly appreciated.
Figured it out guys and what a difference.
Tell us how you figure it out ? Post pix of the cluster please. :cheers:
Here you go gentlemen heres what everyone has always wanted whats negative and positive on the board. This will help you when you want to replace the bulbs with LEDS.
Do they Give off as much heat as the origanal bulbs?? Or does the led bulbs keep the cluster unit cooler?
They barely give out any heat at all and yes they keep the cluster cooler
