looking to get new brakes on a 90 ls 400 but don't know which way to go? i want the ss brake lines and am going to rebuild the calipers also. but as for the rotors, i don't know if i should stick with oem or go aftermarket? i haven't yet but am going to upgrade the wheels to 20" and lower the car but the rotors come in regular, slotted, and drilled/slotted? i know form research that the drilled/slotted is mainly for looks and the slotted dissipate heat better, but the general consensus is that the oem work fine. but how about durability? does the slotted actually last longer than oem due to improved design, or is the cooling benefit mainly a racing feature? has anyone used both before and kow first hand?
thanks in advance! :cheers:
this has been covered more than a few times in the past month alone about aftermarket rotors. The drilled and slotted discussion is also a long and simple one.
i tried a search but didn't find a specific answer, on here and clublexus; i want to know about the durability? do you know? even a rough guess? if not it's cool. thanks for the swift reply!
Start here:
http://us.lexusownersclub.com/forums/index...hl=brake+rotors
sorry! :D i didn't think to search every forum! :cheers:
:cheers: No Sweat, Let us know what you decide.
