Hello,
I did TB and other belts changed Dec 2004 @ 130,000. Now car has 177,000. I knows that TB should change every 60-70K. What about others belt (PS, ALt. etc.)
Thanks in advance.
Edited by camlex
90,000 mile timingbelt & water pump changes. Change the accessory belts then. They normally should last a good 7-10 years. I.E. you'll want to change them with the timing belt.
Edited by Toysrme
Thanks,
It's good to know that TB will last to 90,000.
I will change other belts at sametime.
Again, thanks for your input.
Thanks,
Since you have a 97 if you go over the 90K and the belt break, no big deal.
yeah, unless you are 200 miles out in the desert with no cell phone reception. :whistles:
steviej
wait, what is system that the 97 has that restricts the engine from doing any damage to itself is the t belt snaps??
Edited by element51
There isn't a system, the valves simply don't interffere with the pistons at any orientation. The belt snaps, it's gonna destroy the timing belt covers, and possibly a cam sprocket in the process. Killed ym front sprocket...
