What options on the 2001 LS430 should I avoid? Is the Ultra Package a problem issue as this car gets
older? Should I stay with the standard suspension? What tire option? I'm not looking for handling as much
as luxury cruising.....
Anybody sees a 2001 LS430 deal out there let me know.
Thanks
Craig
If you're going to keep the car a long time I'd definately skip the air suspension.
I agree!!!
Thanks I know your correct about the LS400 series, I've owned 2 LS 400's (91&98) and have consistantly heard that about the LS400 series but the LS430 uses only 10% of its parts from the old LS400 and even the name 'Electronically Adaptive Suspension' sounds different from the LS400 Air suspension???
That may very well be the case, the system is different but its probably still expensive to repair and replace struts.
The full name is actually "Adaptive Variable Air Suspension"
