cebu97 Posted January 3, 2006 Share Posted January 3, 2006 What options on the 2001 LS430 should I avoid? Is the Ultra Package a problem issue as this car gets older? Should I stay with the standard suspension? What tire option? I'm not looking for handling as much as luxury cruising..... Anybody sees a 2001 LS430 deal out there let me know. Thanks Craig Quote Link to comment Share on other sites More sharing options...
SW03ES Posted January 3, 2006 Share Posted January 3, 2006 If you're going to keep the car a long time I'd definately skip the air suspension. Quote Link to comment Share on other sites More sharing options...
nc211 Posted January 3, 2006 Share Posted January 3, 2006 I agree!!! Quote Link to comment Share on other sites More sharing options...
RFeldes Posted January 3, 2006 Share Posted January 3, 2006 Ditto!!! Quote Link to comment Share on other sites More sharing options...
cebu97 Posted January 3, 2006 Author Share Posted January 3, 2006 If you're going to keep the car a long time I'd definately skip the air suspension. Thanks I know your correct about the LS400 series, I've owned 2 LS 400's (91&98) and have consistantly heard that about the LS400 series but the LS430 uses only 10% of its parts from the old LS400 and even the name 'Electronically Adaptive Suspension' sounds different from the LS400 Air suspension??? Quote Link to comment Share on other sites More sharing options...
SW03ES Posted January 3, 2006 Share Posted January 3, 2006 That may very well be the case, the system is different but its probably still expensive to repair and replace struts. The full name is actually "Adaptive Variable Air Suspension" Quote Link to comment Share on other sites More sharing options...
