I'm looking into buying the add-on cd changer for the premium sound Lexus system in my 98 ES. There is one for sale but says it is from a 98 GS3. Here is the model number if it helps Model #CDX-M8076zt. Any advice you can give me would be greatly appreciated. Thanks :cheers:
I would think it would work. Issue is thats built to go in the glove box of the GS.
if you want a cd changer for your es then give me a reply , i will be able to get you what you need :cheers: ;)
from what i know... the cd changer between the ES and GS are the same... and should fit interchangible..
at least thats what i heard from toyota when i was in the conquest of finding a 6 disk for mine.... eventually gave it up and switched the head unit to JVC... and am about to get a compatible 6 or 12 for that ... :magic:
Neiltyme what year ES do you have and how did you go about fitting your JVC in the opening?? You use a mounting kit or custom install?? I was told to look on Autotoys.com but their kits only go up to '96 :cheers:
I got a harness and put in the unit..
Yeah the 97 and Up models are harder to do ... because no one makes a kit for those.... YET..
but try crutchfield.com they actually might have one..
:D :D :D if tou need a glove kit or trunk install reply at dabaysidejill01@att.net and anyone else that would like to replace the stock changer or head unit- nav systems oem only.
thanx :cheers::cheers::cheers:
