O2 Sensor Replacement Didnt Work
Bwilliams
I Own a 91 Ls400 with 132,000 miles. It's the best car I've ever had. I've had it for a year now and I bought it with 119k on it. I finally had the check engine light and trac off lights come on. I researched for days and the common answer was the 02 sensors or the catalytic converter. I took out all 4 sensors and the main ones were ok. The sub sensors however didnt read anything so i replaced them with 2 universal sensors. The sensors I used were 4 wire and the sub were only two wire but when I finished everythhing I checked the capacity on the ohm meter and it registered ok. Thinking everything was finally ok I drove off and the stupid lights came on again!!!!!! I don't see how the catalytic converter can cause the cpu to shut off the traction control. I need help!! Any Ideas????? :wacko::wacko:
I Own a 91 Ls400 with 132,000 miles. It's the best car I've ever had. I've had it for a year now and I bought it with 119k on it. I finally had the check engine light and trac off lights come on. I researched for days and the common answer was the 02 sensors or the catalytic converter. I took out all 4 sensors and the main ones were ok. The sub sensors however didnt read anything so i replaced them with 2 universal sensors. The sensors I used were 4 wire and the sub were only two wire but when I finished everythhing I checked the capacity on the ohm meter and it registered ok. Thinking everything was finally ok I drove off and the stupid lights came on again!!!!!! I don't see how the catalytic converter can cause the cpu to shut off the traction control. I need help!! Any Ideas?????:wacko: :wacko:
When it comes to sensors for our cars OEM is the only way to go.You probably thought you were saving some $$$ right? There are some things you don't take to chance and sensors are one of them.
That's probably part of oyur problem.
You must use like for like AFAIK when replacing sensors. 2 wire should be replaced by 2 wire.
