Hi
i'm sorry if this was posted before, but i have moisture in my headlamps. HOw do i take out the headlight assembly? I know there are two visible screws. Is that it? Can anyone provide instructions? I also need to open out the housing, do i need to put it in the oven? Please help. Thank you
  • 3 years later...
that seems like a lot of work, if you still have the car under warranty they will change the entire headlight unit for free like they did with my car.
  • 4 years later...
Sorry to bump an old thread but google lead me here and decided to give my 2 cents.
So I changed both low-beams today w/o removing the bumper/headlight housings; even with gorilla hands it's possible and doable under 30 min.
The right side is cake and if you need more room then unmount that relay bracket sitting behind the housing. The left side is more of a pain but still easy. disconnect the diag port on the fuse box to make more room and disconnect both harness that connect to the back of the headlights; I believe one connector is for the HID's, and other is the parking light?
