Hey there guys,
I tried searching but couldn't find a definitive answer. I need to replace one of the front turn signals, and wonder if I can use 00-01 signal lens housing on 97 ES300? After all, they are the same body style...
And while I am on the topic, can I buy OEM HID headlights for 00-01 ES300 and install on 97-99 ES300? I might go for a cheaper kit but I'd like to have good cut-offs too. Retrofit is too complicated for me, but I might be able to swap the headlights if they fit :)
Thanks for any help!
A HID kit that is retor fit takes 10 minutes and no tools to install.
To add an OEM kit you can just throw in the lights but the headlight angles will be off . So unless you to adjust the lights it will take longer to install oem .
The headlights are the same from everything i have read in size . Other than them being clear and available in HID there should be no other difference.
The actual reflector inside the lens is probably a different design buit will fit.
Just get a new pair of clear ones from ebay
