sexlex Posted October 20, 2005 Posted October 20, 2005 Was just wondering if anyone has an issue like mine. Whenever I step on the gas from a stop my car doesn't respond right away, causing a hesitiation. It almost appears like the throttle has a dead spot...
GuyTelefunken Posted October 20, 2005 Posted October 20, 2005 Was wondering if you searched these forums yet?
sexlex Posted October 20, 2005 Author Posted October 20, 2005 Going thru that arduous process as we speak....
blue06gs Posted October 24, 2005 Posted October 24, 2005 i kind of have the same problem. and my friend also had a similar problem in his 2001 GS. he reset the ECU by disconnecting the battery cable for about 15 minutes. supposedly this is supposed to reset the computer and relearn your driving style. i'm going to try it on my 2006 gs this weekend.
SW03ES Posted October 25, 2005 Posted October 25, 2005 After your search you'll know but all Lexus built after 1998 or so do this, its a side effect of the throttle by wire system.
nc211 Posted October 25, 2005 Posted October 25, 2005 Yep. After your search you'll know but all Lexus built after 1998 or so do this, its a side effect of the throttle by wire system. ←
