Mechanoman Posted October 15, 2005 Share Posted October 15, 2005 Does anyone know how to do the bypass on 06Lx Models? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted October 15, 2005 Share Posted October 15, 2005 look in the GS section the solution should be similar Quote Link to comment Share on other sites More sharing options...
Ctapia Posted November 22, 2005 Share Posted November 22, 2005 Does anyone know how to do the bypass on 06Lx Models? ← Mechanoman, Did you ever find a solution to this? I have an 04 LX470 and did the fix found here and works great. I'm wondering if this would apply to your 06 as well. 04 LX470 DVD Bybass Quote Link to comment Share on other sites More sharing options...
sidgriggs Posted November 26, 2005 Share Posted November 26, 2005 I have an 06 LX also and was wondering if anyone has done the DVD bypass on an 06 and if it worked--I can bypass the Nav system for destinations while the vehicle is moving, but it has to be done each time the car is started. Quote Link to comment Share on other sites More sharing options...
Ctapia Posted November 30, 2005 Share Posted November 30, 2005 I have an 06 LX also and was wondering if anyone has done the DVD bypass on an 06 and if it worked--I can bypass the Nav system for destinations while the vehicle is moving, but it has to be done each time the car is started. ← Can you please share the details on how to bypass the Nav system for destination while moving? Quote Link to comment Share on other sites More sharing options...
sidgriggs Posted November 30, 2005 Share Posted November 30, 2005 I have an 06 LX also and was wondering if anyone has done the DVD bypass on an 06 and if it worked--I can bypass the Nav system for destinations while the vehicle is moving, but it has to be done each time the car is started. ← Can you please share the details on how to bypass the Nav system for destination while moving? ← A set of button pushes can override the lockout on most 2004,2005, & 2006 Lexus NAVs until the next time the vehicle is restarted by pushing the buttons in the following order: menu > volume > top left of screen, bottom left, top left, bottom left > override ((hold for several seconds until override is highlighted and beep occurs) > back. Destinations can then be entered while moving. Quote Link to comment Share on other sites More sharing options...
Ctapia Posted November 30, 2005 Share Posted November 30, 2005 I have an 06 LX also and was wondering if anyone has done the DVD bypass on an 06 and if it worked--I can bypass the Nav system for destinations while the vehicle is moving, but it has to be done each time the car is started. ← Can you please share the details on how to bypass the Nav system for destination while moving? ← A set of button pushes can override the lockout on most 2004,2005, & 2006 Lexus NAVs until the next time the vehicle is restarted by pushing the buttons in the following order: menu > volume > top left of screen, bottom left, top left, bottom left > override ((hold for several seconds until override is highlighted and beep occurs) > back. Destinations can then be entered while moving. ← Thanks! From memory, I recall the menu button being an actual button (drivers side) but the volume is just a knob and what exactly do you mean by "top left of the screen, bottom left, top left etc"... are these buttons on the Nav screen? Lastly, is this in the manual? Quote Link to comment Share on other sites More sharing options...
sidgriggs Posted December 1, 2005 Share Posted December 1, 2005 Press Menu, on the screen that appears, there is a volume button--press it and you have another screen. Here there are not buttons at the top left corner and bottom left corner, but put your finger in there and push--top, bottom,top, bottom--then a new screen will appear. This new screen has several items listed--just push and hold on the one titled "override"--it will change colors and BEEP. now push back and whereever else you want to go. Try it--it really does work! THIS IS NOT IN THE MANUAL Quote Link to comment Share on other sites More sharing options...
Ctapia Posted December 5, 2005 Share Posted December 5, 2005 Press Menu, on the screen that appears, there is a volume button--press it and you have another screen. Here there are not buttons at the top left corner and bottom left corner, but put your finger in there and push--top, bottom,top, bottom--then a new screen will appear. This new screen has several items listed--just push and hold on the one titled "override"--it will change colors and BEEP. now push back and whereever else you want to go. Try it--it really does work!THIS IS NOT IN THE MANUAL ← Thanks once again! I tried this over the weekend and works great. It's great that you can enable this while in motion and it's set (until you cycle the ignition). I also saw that there's other functions, but didn't mess with them. One more thing... would you happen to know how to enable this same mode on earlier LX/LC, like an 03? CTapia Quote Link to comment Share on other sites More sharing options...
BR_LX470 Posted February 13, 2006 Share Posted February 13, 2006 Did you ever get the 06 DVD bypass to work? If you have any tips/pictures, please let me know. Thanks Quote Link to comment Share on other sites More sharing options...
sidgriggs Posted February 13, 2006 Share Posted February 13, 2006 Did you ever get the 06 DVD bypass to work? If you have any tips/pictures, please let me know. Thanks NO DVD Bypass yet--without buying and installing another product. Quote Link to comment Share on other sites More sharing options...
Jim_Chow Posted February 14, 2006 Share Posted February 14, 2006 Does this work on the 03 LX's? Quote Link to comment Share on other sites More sharing options...
greggebhardt Posted February 16, 2006 Share Posted February 16, 2006 Press Menu, on the screen that appears, there is a volume button--press it and you have another screen. Here there are not buttons at the top left corner and bottom left corner, but put your finger in there and push--top, bottom,top, bottom--then a new screen will appear. This new screen has several items listed--just push and hold on the one titled "override"--it will change colors and BEEP. now push back and whereever else you want to go. Try it--it really does work! THIS IS NOT IN THE MANUAL WOW! I can't thank you enough! :) Quote Link to comment Share on other sites More sharing options...
sidgriggs Posted February 16, 2006 Share Posted February 16, 2006 Yes Try it. also go to www.clublexus.com--do a search for Nav Bypass-- you will learn more ways to do the bypass Quote Link to comment Share on other sites More sharing options...
dtech Posted August 25, 2006 Share Posted August 25, 2006 Has anyone got this to work on the LX2003? Thanks. Quote Link to comment Share on other sites More sharing options...
heykev Posted August 25, 2006 Share Posted August 25, 2006 Since we're on the subject of bypassing, does anyone know if we can bypass the first screen, the disclaimer screen?? 2006 LX Quote Link to comment Share on other sites More sharing options...
