Need Help Finding Hub Rings For Rpm 505 Wheels
Got RPM 505 19'' rims, my steering vibrates betwen 50-65mph. Does anyone know where i can get hub rings, that perfectly fits (wheels and hub*)
Dealer won't co-op anymore (damn,waisting my time) Called manufacturer and they sent me back to dealer i bought rims from. It bothers me like a M*********R, Need seriuos leads, thanx in advance- Jake
"GS400 Built to perfection, by ME " with YOUR HELP
Here is the easy part ask the company that sells RPM wells or maker what the center bore is.
Then you will be able to source a ring with an inner bore of 60.1 (toyota/lexus) with the outer diameter matched to your wheel.
Other than that you need to go to a rim and tire store who can take the rim off ,measure the bore and match one to it.
Make sure you are not using the oem toyota nuts as they don;t fit right if at all.
If you want a quick fix loosen each wheel so the nuts are loose but still on.
then slowly rotate the tire wiggleing it around as you tighten the nuts. It will snug the rims more centered.
Yeah, you're right-Thanks bro, gotta call tomorrow and check it out
