Bourne33065 Posted September 21, 2005 Share Posted September 21, 2005 Hey, recently I got in the car and the radio was on, so as the antenna was going up I pushed the off button it started to retract but didn't all the way, so I messed with the gear box in the trunk to get it to go down, but now when I turn the radio on it will make a noise like it's trying to push it up, and the tip comes out it makes that noise and it goes back in. the noise was also there when the antenna was just sticking out. Is there any way to fix this? And does anybody else have a problem with their radio where as soon as they turn the car on and you try and change stations VIA presets or change from cd to fm or vice versa it doesn't change right away? Quote Link to comment Share on other sites More sharing options...
JDOwen2 Posted September 21, 2005 Share Posted September 21, 2005 You need a mast replacement. Ebay. Quote Link to comment Share on other sites More sharing options...
Bourne33065 Posted September 22, 2005 Author Share Posted September 22, 2005 Sweet thanks for the info, is it alot of work to fix? You need a mast replacement. Ebay. ← Quote Link to comment Share on other sites More sharing options...
