Ok I hooked up some PILOT fog lights to my 1992 SC 300. When I have them on I smell something burning but then after a few days it's gone, but my side markers, parking lights, and fog lights are no longer working. I checked the fuses and they all seemed fine. My head lights, taillights, and brake lights are all working. Some one please help me. Does anyone have the same problem or a fuse diagram to the one on the driver side panel? I would greatly appreciate the help. :unsure:
Same thing here i hooked up fog lights,,they worked for a few month. Now i have no fog lights or park light. I cant find the problem. :huh:
May be an electrical part that has been damaged. Best to take it to toyota if you checked the fuses and everything appears to be fine. How did you wire the fog lights in?
What did you use to hook up the power -12 and +12 and the remote turn on?
Where and what wires were they from?
I had my fogs conected to park lights , which are now dead as well as the foglights.. I dont see no fused for fron park lights either
Try a little more detail.
Read what i asked again and reply with the exact info.
Ok i conected both + and - directly to my fogs. they did work for a few month. So fogs would turn on with park lights
where exactly did you tap the wires for the fogs AT ?
If i am reading this right ,you wired a 110 watt set of lights to a 15 amp set of wiring ?
If so ,no wonder it doesn;t work any more.
I would check your relays.
I wired them at the closest spot posible which is conection behind the park lights.. O and
I forgot to mention ,,,all i did was converter the lower turn signals to fog lights that would be on all the time,,but im not sure waht the power rating is on those.. I will check relays,,,are they in the fuse box under the hood???
ok I connected my fog lights right behind where the parking lights are. Then it worked fine for a few days, but after the few days the sidemarkers, parking and fog lights goes out. Although, the headlights and all my rear lights are normally functioning. I think I could have damamged something or a fuse is out. So I checked all my fuses and the light bulbs, but everything seems fine. However I haven't check the relay because I can't locate it. Can someone tell me where to find it?
SHould be under the hood in the fuse block area , read the descriptions of each one in there.
I checked everythink i coul find... There are no fuses for park light,,,kinda odd,,,,,,
Anyone know where the fuses for parks are?
Take it to a technition.
I said "I would check your relays"
then you asked me where and i said "SHould be under the hood in the fuse block area , read the descriptions of each one in there"
I never said to check fuses
There are no relays for park light that i could find under the hood or under the dash.
Check the relays in the cabin fuse block are then.
Listen for where the headlight relay is and it should be right by it.
Just keep turning the lights on/off to trace the clicking.
Well the headlight relay is in the box under the hood I did find that, but there is no relay there for park lights,, very strange...
If you want to be adventureous i would go to lexus and buy the schematic book and trace back where the wring is and goes .it is about 30 and is well worth it when you get these wiring troubleshooting issues.
Not sure about the SC, but in my LS, the interior cabin fuses housed one for the parking, lights etc.  It should be marked for "TAIL LAMPS".
well my tail lamps work just fine
