bran1974 Posted July 15, 2003 Posted July 15, 2003 I want to rotate my tires on my 98 es300. Do I criss cross them? How do I rotate them?
NeiLtYmE Posted July 15, 2003 Posted July 15, 2003 just go in a circle... some say to criss cross them ... but it really doesnt matter.... from what i have observed .. that is
es3doubleO Posted July 15, 2003 Posted July 15, 2003 You can rotate them by putting the front in the rear and the rear in the front. Lexus recommends this every second oil change, but i think if you have 17" and up every oil change due to tire wear.
jhauck Posted July 15, 2003 Posted July 15, 2003 "my two bits". First look at the sidewall of the tires. If they are directional (i.e. having markings designating left and right) then you must rotate them front to back. If they are non-dirctional, then you can criss-cross the rotation. My Toyo Proxes TPT's are directional and marked "left"/"right", therefore should only be rotated front to back.
chillaxin Posted July 15, 2003 Posted July 15, 2003 i think that as long as the tires aren't specifically directional, its recommended that you criss-cross them. i believe the reason for that is because the outside of the tires usually wear down more than the insides, so by criss-crossing them, you can sort of even the tires out, or something along those lines. i think the specifically directional tires are made so that they don't wear out on the outside like normal tires. have fun rotating! :)
steviej Posted July 16, 2003 Posted July 16, 2003 my '02 manual shows front to back only. On all my radial tires, I have only swapped front to back. Never had any problems as long as the tire pressure was checked regularly, and the car was always aligned. I can only go F to B with the Toyos cause they are directional. ps, I never rotate the spare. It stays in the trunk in the dark but is checked occasionally to make sure it always has air. sj
