Anyone ever take your keys into the ocean? I know you can put the remote in your trunks but what about the key? There's some chip in there -- is it going to get messed up by the salt water?
Like many electrical items out there. Maybe, maybe not depending if it was activated while wet, submerged, shark attack, jellyfish sting whatever. Heck, I guess a full moon could be an issue too...somehow.
In my experience, I have rinsed in fresh water, opened it up and allowed to air dry while rotating it around to avoid water sitting while drying and giving the false sense that after a few hours/days, it should be dry.
Try it and see...won't know till you try.
Common sense.
At least if you go to the beach put it in a zip lock.It is only a small rubber seal which will be easily compromised.
Or leave your keys in the car and only take the wallet key with you attached to a key ring around your chain if you wear one.
