rexlex Posted August 28, 2005 Posted August 28, 2005 How do you flush the cooling system? Where are the block drain plugs? How much is in the block if I just drain and fill? How do you drain it? Should I use pink or red? Full strength or 50/50? How much should I buy? How much does it hold? Should I replace the thermostat? Thanks
SKperformance Posted August 28, 2005 Posted August 28, 2005 What is your experience level in automotive maintenance and repairs? All quantities are listed in the owners manual at the back of it.
rexlex Posted August 28, 2005 Author Posted August 28, 2005 What is your experience level in automotive maintenance and repairs?All quantities are listed in the owners manual at the back of it. ← I have done flushing and just drain and fill in many of my american cars. Also changed the plugs in my RX but dont have a repair manual for locating some things as others are common sense. Some capacities are not always the same as the manual. Usually do all my own maintenance and repairs except tire replacement, tranny flush, and some timing belts.
rexlex Posted August 29, 2005 Author Posted August 29, 2005 I would just call and ask a dealer to send you a picture of where the plugs are because no one here cares and never will so just get lost and shut up!
