Cleaning The Abs/ Traction Sensors
sjc6765
  • 1 year later...
Be Careful...they are easy to break when you remove them. I had my mechanic do it and we lost a sensor. Cost me about $200...still, it didn't fix the TRAC lite falure. WE ARE BAFFLED. So, I wouldn't recommend going
that route.
Trac light failures that are related to the sensors have to do with a bearing failure but the sensor is fine. It is almost impossible to press the old ones out so when you get new bearings on a new hub it will have to get a new sensor as well.
