Hello all from a newbie. Thanks for this great forum. I keep reading of the PVC valve and to replace it. I have a great 96' ES-300 (currently at 91k). But when having my oil changed, I was told the vehicle did not have one. So I suppose the question is, does it or does it not have a PVC valve? If so, where is the darn thing located, where can I purchase one and how is it replaced? I know this sounds like a hokey question, but I have to learn or pay the piper at Lexus. I prefer the embarassment of the former! :whistles:
rockit...Suggest checking in General Maintenance forum. You'll have better luck there.
Thanks
rokit, PVC is a white plastic tubing used commonly in plumbing and electrical work.
PCV is the abbreviation you are looking for: Positive Crankcase Ventilation.
do a search on "valve" and limit it to the ES forum. you should get loads of threads
steviej
steviej
Thanks again Steve....Now I am majorly embarassed !
It should be on the valve cover. Also it takes about 45 seconds to do. I also put some silicone or light grease (very small amount) on the new one so it is easy to push in.
Side note: I replace them every 35 to 45K miles since they are cheap. Just put on in yesterday. It cost $5.95 (shipped and an OEM one)!
Looking for my PCV on my 2vz-fe. Thread right below this one...lol... :whistles:
3vz-fe, blue arrow is the PCV valve
2vz-fe, blue line should be the location. It's behind all the stuf fin the picture, on the rear valve cover like the 3vz-fe.
In the top pix, it looks like someone needs to spend about $1.00 on some rad hose clamps; zip ties to not work all the time!  :D ;)
lol mburn!! :whistles: :lol:
:cheers:
When you can turbo a once turboed engine for less than $500, call me.
It's got hose clamps on it now, those pictures from my photobucket must be 6 months old by now.
Thanks Mike. I found the location this morning and changed it out. It was full of gunk too. And thanks for the heads up, with changing them around every 35-45k miles. Good advice. Cheers
