Do I Need Shocks?
If you are replacing the springs to lower the car, you may as well replace the shocks too. Otherwise, you will pay double for the same labor when your shocks go bad. KYB AGX are a good brand to use with lowering springs.
i know its more expensive but what about the convinience factor if you dont like the ride hight you have to change springs and how much is that going to cost not to mention the extra time it takes to change springs compared to just spinning adjusters
