ED. Posted July 15, 2005 Share Posted July 15, 2005 I tried both sets of instructions the ones that came with it and the ones from this site and neither worked. So then I called Lexus and asked them how much it would cost, my orginal intenet was to go to a Toyota dealer but I wanted to ask Lexus if it was the same procedure, and when the lady came back on the phone she said it was FREE!!! All it would would take is about 30 minutes. So tomorrow at 9am I find out if this remote works. It should since both codes are the same. If not I am gonna send it back to the guy I bought it from. thanks Quote Link to comment Share on other sites More sharing options...
sha4000 Posted July 16, 2005 Share Posted July 16, 2005 i had the same problem but i got the remote thats built into the key only to find out that the key is cut differently which of course i should have known and i cant program the remote all the fcc# are the same though so i was thinking of buying an uncut key without the fob and getting it cut at a locksmith then put the fob that i bought into it and see if the dealer up here will program it for free what do you think ed?will this work?the part about getting a ke cut by a locksmith its still cheaper than what the dealer will charge for one and im already commited Quote Link to comment Share on other sites More sharing options...
ED. Posted July 16, 2005 Author Share Posted July 16, 2005 I forgot your year had the different key. I am not sure if a locksmith can cut a Lexus key? If he can I would then go to Lexus and explain your situation. If one says no then I would go to the next and so on. If they all say no I would try Toyota. They might be able to program it for you. Worse case you could come down to St. Louis and go to the place where I'm goin : ) thanks Quote Link to comment Share on other sites More sharing options...
sha4000 Posted July 16, 2005 Share Posted July 16, 2005 I forgot your year had the different key. I am not sure if a locksmith can cut a Lexus key? If he can I would then go to Lexus and explain your situation. If one says no then I would go to the next and so on. If they all say no I would try Toyota. They might be able to program it for you. Worse case you could come down to St. Louis and go to the place where I'm goin : )thanks ← im not too pressed about it right now but i will let you know what happens Quote Link to comment Share on other sites More sharing options...
ED. Posted July 16, 2005 Author Share Posted July 16, 2005 I just got back from the Lexus dealer. I gave them the new remote and old remote/key and in about 10 minutes he handed us both and said thanks. I wonder what i was doing wrong? thanks Quote Link to comment Share on other sites More sharing options...
