Do you have an owners manual and a maintenance manual? If not, sign up on Lexus.com. I had the 60K service performed on my 2000 LS a few weeks ago. I follow the normal maintenence schedule except that I have the transmission and differential fluids replaced every 30K instead of never.
I always exclude oil changes (I do it myself) and wheel balancing/rotation (I use a specialty wheel shop) from what I ask the repair shop to do.
The 60K maintenance on my 2000 LS cost $375 before taxes excluding the engine oil/filter change and tire balance/rotation but including the additional fluid change services described above.
The normal 60K service on a 2000 LS includes engine oil/filter change, brake fluid and coolant changes, air filter and cabin filter, tire balancing, various inspections, and a road test.
The 60K service on a 2000 LS is fairly minimal and less expensive that the 60K service on the LS I bought in 1990.
Thanks for your input.
