Check Engine. Code 466 Help...97 Es 300
nnt
  • 1 month later...
I suspect this code means that your charcoal canister in your evaporative control system is becoming defective, hence setting off the check engine light. You should bring your car to the dealership to verify that is so (I'm pretty sure that's the problem), and then have them do the job. Parts and labor could run between $500-$600. Depending on your mileage, check with your Lexus warranty and see if it can cover the work.
