Transmission Fluid Question
Tarrant
Hey guys. Looking thru my IS300 manual, it says to use Type IV automatic transmission fluid. I was going to be changing it out soon (or have it changed out by someone else) and wanted to put in Mobil 1 Synthetic ATF. Here's the link...
http://www.mobiloil.com/USA-English/MotorO...thetic_ATF.aspx
But it doesn't say on their website, or on the bottle, anything about being Type IV (whatever that is). Does anyone know if this stuff will work okay? Thanks again for the help!
My 2001 ES requires the Toyota type IV tranny fluid too. No, you can not use the Mobil 1 synthetic tranny fluid. However, you can use Amsoil synthetic ATF as it IS compatable with Toyota Type IV. I will be changing to this fluid (just a drain & fill this time) later this year. Here is some more product info & hope this helps! B)
http://www.amsoil.com/storefront/atf.aspx
:cheers:
