i here that the charging system on the ES300 has a problem with low output at idel and that lexus changed the pully on the 97's. has anyone tryed to do the swap i know how to do it i just need to know if it requiers a diffrent belt and if this aculy solved the low output problems :cheers:
Don;t know anyone who changed it but the highlader is a higher output one.
The RX should be the same one since it is a twin
What he told you, A highlander alt is a 130amp unit vs the 80amp's typically installed across Toyota's car line.
