dpallenman Posted April 28, 2005 Share Posted April 28, 2005 Hi there. I have the opportunity to purchase four new 215/60/16 snow tires for my 2000 ES300 at a significant discount. Of course, the stock size is 205/60/16. Has anyone ever tried a 215 on an 2000 ES300? I just want to make sure the extra width will not cause problems. Darren Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted April 28, 2005 Share Posted April 28, 2005 Hi there. I have the opportunity to purchase four new 215/60/16 snow tires for my 2000 ES300 at a significant discount. Of course, the stock size is 205/60/16. Has anyone ever tried a 215 on an 2000 ES300? I just want to make sure the extra width will not cause problems. Darren ← According to the tire rack website, it does not suggest that size as a possible alternitive. Generally, snow tires are usually slightly smaller (or the same factory size), not larger (even though it's a 'slight' bump us in size). Check with a couple of tire dealers before going ahead with the purchase. Perhaps that's one of the main reasons why you can pick them off so cheap? ;) Quote Link to comment Share on other sites More sharing options...
mxl4729 Posted April 29, 2005 Share Posted April 29, 2005 Hi there. I have the opportunity to purchase four new 215/60/16 snow tires for my 2000 ES300 at a significant discount. Of course, the stock size is 205/60/16. Has anyone ever tried a 215 on an 2000 ES300? I just want to make sure the extra width will not cause problems. Darren ← According to the tire rack website, it does not suggest that size as a possible alternitive. Generally, snow tires are usually slightly smaller (or the same factory size), not larger (even though it's a 'slight' bump us in size). Check with a couple of tire dealers before going ahead with the purchase. Perhaps that's one of the main reasons why you can pick them off so cheap? ;) ← the snow tires are only 10mm wider and 6mm higher. that is almost nothing. i would make sure you have 5mm on each side to spare and if u do you can fit them on. Quote Link to comment Share on other sites More sharing options...
