Cgraham718 Posted April 22, 2005 Share Posted April 22, 2005 Hey I was reading through the forum and came across a post asking about what type of oil the rear differential takes. Where do u check the oil level for the rear differential? How do u fill it? I ask because about a 2 weeks ago I started to notice some "jumping" when I get to the car and shift from park to rev etc... Before I couldn't even tell when I was switching gears. The jumping feels like it's coming from the rear of the car. It only does it when I'm switching gears from a stopped position and it doesn't do it all the time. I don't notice any difference in shifting while driving. I have a 98 GS 300 Any ideas? Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted April 22, 2005 Share Posted April 22, 2005 Hey I was reading through the forum and came across a post asking about what type of oil the rear differential takes. Where do u check the oil level for the rear differential? How do u fill it? I ask because about a 2 weeks ago I started to notice some "jumping" when I get to the car and shift from park to rev etc... Before I couldn't even tell when I was switching gears. The jumping feels like it's coming from the rear of the car. It only does it when I'm switching gears from a stopped position and it doesn't do it all the time. I don't notice any difference in shifting while driving. I have a 98 GS 300 Any ideas? ← It dosen't explain things in your owners manual? If you don't have one, contact Lexus USA directly & from what I hear, they will mail you a free OM. B) Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted April 22, 2005 Share Posted April 22, 2005 I don't think the owner manual would cover the diff, it's not an item you check normally. There should be a threaded plug on the side of the diff, on a level surface, unscrew the plug and the oil should be level with the bottom of the hole. I replaced mine with Amsoil oil even though the original looked fine. However, your problem sound more like a tranny or driveshaft problem. <_< Quote Link to comment Share on other sites More sharing options...
NJLexusGS Posted April 27, 2005 Share Posted April 27, 2005 I never actually looked at mine. But there should be a rubber plug in the differential casing. If you pop the plug out and the oil comes out, that means you have enough. You can either check it on a lift or crawl under the car. If you pop the plug and there is no oil coming out, you might wanna add some oil. You can use gear oil.... I am pretty sure the label on it says 85W Gear Oil. Quote Link to comment Share on other sites More sharing options...
Cgraham718 Posted May 9, 2005 Author Share Posted May 9, 2005 Thanks guys!! Yes Lexus does send you a new owners manual for free. It didn't have any specific info about the differential oil but is was still good to get. I went to the maintenance forum and someone in there had a pic of the process. There are two Hex screws, upper to fill lower to drain. It was really easy!! Thanks again Quote Link to comment Share on other sites More sharing options...
