bobreamon Posted April 8, 2005 Share Posted April 8, 2005 I just bought a '92 SC300. I love it, but I have a problem. The "heater" fuse (#2 slot, 10A) kept blowing, with or without AC on. Tried 15A, they blew also. Then 30A which won't blow. I noticed a pully noise, so checked under the hood and the AC compressor clutch turns slowly, intermittently at idle. Turn on the AC and it blows cold, but goes on and off (climate control) and the light blinks. If the compressor was shot, I wouldn't get cold air. Any ideas? Quote Link to comment Share on other sites More sharing options...
DomLee Posted April 8, 2005 Share Posted April 8, 2005 Sounds like either something isn't grounded/wired in properly. Was the car ever in an accident? Reason I ask is because if the car was in an accident and body panels (and other parts) were reinstalled...they may have accidentally pinched a wire or two thereby not properly grounding the wires. (This happend to me on one of my cars). Quote Link to comment Share on other sites More sharing options...
bobreamon Posted April 8, 2005 Author Share Posted April 8, 2005 Thanks. I'll check it out, although there was no record of any accident and the body/paint all seem original. Quote Link to comment Share on other sites More sharing options...
JDOwen2 Posted April 11, 2005 Share Posted April 11, 2005 You're living dangerously if you leave that bigger fuse in. Possibilty of an electrical malfunction or fire is greatly increased. Quote Link to comment Share on other sites More sharing options...
bobreamon Posted April 11, 2005 Author Share Posted April 11, 2005 Thanks. Actually, a mechanic friend put in the 30A to see if there was any life in the climate control and/or compressor. I'm not running it at all right now (it's 60-70 degrees here) until I find the problem. I'm checking some things today. Quote Link to comment Share on other sites More sharing options...
