blue400 Posted June 25, 2003 Share Posted June 25, 2003 hi, i just installed a phillips 6000k hid system into my car( i have a 91 Ls400) and on the right its is very white, but on the left it is very yellow. does any one know what the problem is? and also can i put different brand hid globes onto the system?...... one more thing i have 235/35/18 on all four wheels, i was wondering if i can go any wider on the rear? thanks Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 25, 2003 Share Posted June 25, 2003 Well, HID lamps go yellow when thy're about to go bad. What brand was your upgrade kit? Try taking the bulb out and seeing what color it is on its own, try switching the bulbs side to side and see if its just that lamp that is yellow, or the bulb itself. Could be buildup in the lamp. Quote Link to comment Share on other sites More sharing options...
chromiez Posted June 25, 2003 Share Posted June 25, 2003 i have a 1991 ls400 too, how much did it cost you for the HID kit? i was thinking of getting one. how does it look? cause the stock headlamp isnt clear, it has those werid patterns on it. Quote Link to comment Share on other sites More sharing options...
BG LEX Posted June 26, 2003 Share Posted June 26, 2003 by '6000k HID system' does it mean just the 9004 HID BULB? or any other changes in the headlight? also are there any after market CLEAR front headlights available for our cars? Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 26, 2003 Share Posted June 26, 2003 Nope, not that I know of. The kit is a bulb retrofit that replaces the 9004 bulb, it also includes a ballast that powers the stystem/ "6000k" is the color temperature, that is, the color the bulb gives off. All stock systems are 4100k, 6000 is more purple, 8000 even more so, hell they even have 12000k units out there. Anything over 6000 is useless though, they coat the bulbs making them give off less light. Quote Link to comment Share on other sites More sharing options...
chromiez Posted June 26, 2003 Share Posted June 26, 2003 actually there is an aftermarket clear headlamp. i seen it on another lexus forum freakin nice!!! but too expensive...i think i remember the guy said it cost around $1000 to import it here to the USA atleast. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 27, 2003 Share Posted June 27, 2003 That does look nice, and actually, $1000 is probably on par with replacing the lamps from Lexus... Quote Link to comment Share on other sites More sharing options...
