Ebenada Posted March 22, 2005 Share Posted March 22, 2005 Hey fellow Lexuseses Owners! This forum is great...I "found" it earlier today at work and have been reading post like crazy....everything from warming up engines to Oil filter recommendations. have a quick question... Key Fobbs (at least that's what I think they are called)..you know the little black 3 button thing which attaches to your key ring....you can unlock your door and your trunk with it. I have the model where the key and the "lock/unlock/trunk/panic" button is separate. Well, apparently I cant get one anywhere...the dealer has told me to replace it will be roughly about $200. The problem I have is that 1) my battery is dead (that is an easy problem), and 2) the loop that goes around the key ring is broken. So, does anyone know where I can get a new case and/or battery for my Key fobb. When I figure out how, I will post pics of the car!!! Quote Link to comment Share on other sites More sharing options...
IlyaIlya Posted March 23, 2005 Share Posted March 23, 2005 ebay 25-45 bux, make sure you get the right #, check one you have and get same #, and you are set, good luck, Quote Link to comment Share on other sites More sharing options...
Ebenada Posted March 23, 2005 Author Share Posted March 23, 2005 ebay 25-45 bux, make sure you get the right #, check one you have and get same #, and you are set, good luck, ← Thanks for the Heads up. Hey, I see on ebay key fobs for Toyota Avalons. Is it possible to replace my broken key fob body with this body but still keep the "guts" of my key fob? (hope that makes sense!? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted March 23, 2005 Share Posted March 23, 2005 should be fine Quote Link to comment Share on other sites More sharing options...
steviej Posted March 23, 2005 Share Posted March 23, 2005 as for the batteries, they can be had at CVS, Walgreens, WalMart, any Autoparts store, RadioShack, etc. Use the number on your existing battery to match up. steviej Quote Link to comment Share on other sites More sharing options...
