Going to replace the rear diff. gear lube for 95 SC400 this coming weekend. Could I get the opinions of the best weight and and name brand to use as well as if I need any additives to help keep the limited slip working (like old whale jiz). What is the best additive by name? Synthetic lube ? Thanks
I just put in Mobil 1 75W-90 full synthetic. Good stuff. You will need two qts. No need to use additives with this stuff.
Good luck
I like synthetic in manual transmissions but in that limited slip diff. I'd use the Toy/Lexus OEM stuff, only 2 qts.,good for 60k or so, pretty good insurance.
