I would like to replace my OEM rubber bushings on the FSB with urethane. What are recommendations? When replacing FSB rubber, what else should be replaced besides the main bushings?
Also, I have ordered a TRD RSB, will it come with bushings? Is there any rubber I should replace when installing the TRD RSB?
Thanks,
Dan
Why do you want to replace them ?
Whiteline makes replacment bushings.
Unless it says it comes with new bushings it probably wont .
I just installed KYB struts and mounts. I have ordered Solara strut bar and TRD RSB. So I wanted to move to urethane on the bushings and stabilizer links. Reason: increased durability and better performance over OEM rubber. My existing bushing/links are OEM rubber that is 8 years old and 75K miles.
I have looked at energysuspension and whiteline, but am confused on what parts will work. I also do not see urethane stabilizer links.
Any help here would be appreciated.
Thanks,
Dan
stablilizer bushings should be called end links i think
I know they sell then as some people have them and had to get whitelines for the upgraded larger bars
