Radio Light '92 Es300
that could be a number of things.First check all the fuses and make sure they are all good.next if that dont work then it could be a wire behind the radio.pull it out and check and make sure there all connected.if none of that works then its probably the radio but i doubt it.i think its somewere in the fuse box.
i dont mean the radio fuse. i meant a different fuse that might be tied into the illumination.like i said i think its a wire somewere if not the fuse box.unless the radio did burn out but thats doubtful.
