BowtieJC Posted February 5, 2005 Share Posted February 5, 2005 I just washed off the engine and now it is missing real bad ,it won't run good enough to drive, any ideas of what too look at , I guess something is wet but what. It is a 93 SC300. Any suggestions woulkd be appreciated. Quote Link to comment Share on other sites More sharing options...
TMaxxTim Posted February 5, 2005 Share Posted February 5, 2005 I just washed off the engine and now it is missing real bad ,it won't run good enough to drive, any ideas of what too look at , I guess something is wet but what. It is a 93 SC300. Any suggestions woulkd be appreciated. ← Its the sparkplugs, they get water in them and miss. Its the back 2 that seem to collect the water. I've had the same problem after it rains sometimes and the first time after my engine got washed off. Take off your covers and see if you can suck the water out with a shop-vac or stick a rag in there to soak it up. Its not easy to get to but I'm 99% sure thats your problem since its right after an engine wash. Quote Link to comment Share on other sites More sharing options...
BowtieJC Posted February 5, 2005 Author Share Posted February 5, 2005 I just washed off the engine and now it is missing real bad ,it won't run good enough to drive, any ideas of what too look at , I guess something is wet but what. It is a 93 SC300. Any suggestions woulkd be appreciated. ← Its the sparkplugs, they get water in them and miss. Its the back 2 that seem to collect the water. I've had the same problem after it rains sometimes and the first time after my engine got washed off. Take off your covers and see if you can suck the water out with a shop-vac or stick a rag in there to soak it up. Its not easy to get to but I'm 99% sure thats your problem since its right after an engine wash. ← Quote Link to comment Share on other sites More sharing options...
BowtieJC Posted February 5, 2005 Author Share Posted February 5, 2005 Thanks alot I will go try that right now. Quote Link to comment Share on other sites More sharing options...
BowtieJC Posted February 6, 2005 Author Share Posted February 6, 2005 I tried to dry out spark plugs and let it sit overnight with the sparkplugs wires out of the distributor so this morning I put them back on and it still is missing. Any other suggestions. Quote Link to comment Share on other sites More sharing options...
stockgixer Posted February 6, 2005 Share Posted February 6, 2005 Suggestions: 1) Check all cables. vacuum lines that nothing got disconnected during the wash 2) See if you're getting a spark on each of the cables. 3) If yes, not a bad idea to inspect each of the plugs to make sure they are ok. Quote Link to comment Share on other sites More sharing options...
JDOwen2 Posted February 6, 2005 Share Posted February 6, 2005 You could pop the distributor cap and check for moisture. Quote Link to comment Share on other sites More sharing options...
gcarpent Posted February 6, 2005 Share Posted February 6, 2005 While you have it apart check the resistance on each of the plug wires. the resistance should not exceed 25K ohms on any wire. Quote Link to comment Share on other sites More sharing options...
IFixEm Posted February 7, 2005 Share Posted February 7, 2005 You could pop the distributor cap and check for moisture. ← Our detail department is pro when it comes to fillingthe cap with moisture. Pop the ap and dry it out with a kleenex. Check for grey lines in the cap if you have run with the miss for a long time. To prevent this in the future be carfull where you spray, and coat the bottom of the cap sealing surface with lipbalm. I prefer the wife's expencive avon lip balm. Quote Link to comment Share on other sites More sharing options...
BowtieJC Posted February 7, 2005 Author Share Posted February 7, 2005 Thanks alot, I fixed it The distributor cap had moisture in it and also a hair line crack, I replaced the wires,plugs , cap and rotor button, while I was doing it.It is fine now . Quote Link to comment Share on other sites More sharing options...
