Tylermng Posted January 17, 2005 Share Posted January 17, 2005 I have an 2000 RX300. Recently the throttle needs excessive force to be depressed while at rest. It seems to get worse as the car warms up. I lubed up the entire cable and throttle assemblies. It didnt do much good. Is there any way to adjust the cable? It seems kind of loose. I see a set screw on the throttle. Will this tighten up the cable. The throttle itself iseems fine, its just the resistance on the initial depression of the pedal. Any ideas? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 17, 2005 Share Posted January 17, 2005 you need a throttle body cleaning it needs to be cleaned on the insdie of it not the outside Quote Link to comment Share on other sites More sharing options...
jbarhorst2 Posted January 18, 2005 Share Posted January 18, 2005 I agree. I had the same problem on my '97 SC300. Once I cleaned the throttle body everything was smooth again. Tom Quote Link to comment Share on other sites More sharing options...
