when I use to peel out i would have two tire marks "both wheels would spin... " now only one wheel is spinning but i did get into a accident "a hit n run" and i slammed my right wheel into a curb and it dent the axle, but the right wheel is the one that is spinning, please tell me if this is normal or what? thank you.
depends on if you have the last option on your car
it woudl leave 2 marks if it has it
might need to change your diff oil
an lsd is (limited slip differential) it stops one wheel from spininng by locking the 2 together thus creating both wheels to spin and distribute the power evenly.
so it would leave to skid marks not one instead for each wheel
the year means nothign as it is an option when making the car if you have full leather not micro suede then you just might have a lsd
I believe the confusion arose from the word last, which means nothing.
:D
yeah, I was thrown by that too.
does your ES have traction control? Some RWD cars are equiped with it.
steviej
sorry
bby last i meant the last option package which is "C" in canada of a,b,and c which includes leather and the lsd
Get the rear diff. checked by the dealer. I did the same to another car that was posi and after i hit the curb, one-legger hole-shots until I fixed the parts I broke in the diff. Hope this helps.
well io have the suede in the middle in between the leather, both wheels use to spin i know for a fact, but now only one wheel spins
