K9crew Posted December 29, 2004 Share Posted December 29, 2004 OK .. as typical LS400 owners, when can we expect to have to rebuild the front steering/suspension components i.e. ball joints, bushings, shocks, springs etc? I have 73k on my LS now and the front end is very loose. Potholes, speed bumps, bad asphalt etc are no fun. The right front knocks quite badly pulling into my driveway even going slowly. I'm guessing that I need new bushings or possibly ball joints in the front along with bushings for the bar that ties the front suspension to the chassis. I'm replacing all four rotors this weekend with cross drilled/slotted that I've had for a while because my front rotors are badly warped. I plan on taking a good look at the front suspension and putting together a parts list that I can take to the local dealer. I'm sure that it's going to cost an arm and a leg for all the parts that I'll need. :) Quote Link to comment Share on other sites More sharing options...
VBdenny Posted December 29, 2004 Share Posted December 29, 2004 Are you sure? Unless you pound the car over really rough roads and abuse it (which I doubt you do) I can't believe all that stuff is bad. These suspensions are quite tough with the weakest part being the strut (or torsion bar looking things) bushings. Mine had a slight pull to the right and when I replaced those it was galssy smooth. The upper wishbone control arms also tend to weaken but go bad very slowly. Quote Link to comment Share on other sites More sharing options...
RFeldes Posted December 29, 2004 Share Posted December 29, 2004 Seems like low mileage for those problems but all depends on your road conditions or too many speed bumps. In any case I would try the silicone spray as was on a recent thread on all the ball joints and see if that doesn't quieten things down. It worked for me. But as you are in Hawaii, cold weather stiffness should not be a problem. But shimmy and shake point to a more serious problem. I'm sure when you do the rotors you will be in a better position to assess the problem. Good luck and let us know what you find. Quote Link to comment Share on other sites More sharing options...
K9crew Posted December 29, 2004 Author Share Posted December 29, 2004 Thanks guys. At this point I'm not sure what needs to be done but I should have a better idea this weekend. It could be the bushings on either end of the bar (runs fore and aft) that connects the front suspension to the chassis ... I've read about those bushings going bad which can result in a clunking front end. I'll certainly let you know what I find. :) Quote Link to comment Share on other sites More sharing options...
99lsguy Posted December 29, 2004 Share Posted December 29, 2004 Thanks guys. At this point I'm not sure what needs to be done but I should have a better idea this weekend. It could be the bushings on either end of the bar (runs fore and aft) that connects the front suspension to the chassis ... I've read about those bushings going bad which can result in a clunking front end. I'll certainly let you know what I find.:) ← Hey K9!!! Good to hear from you again....My LS is @ 69,500 miles.....nearly your twin :D Those "front strut rod bushings" are prone to failure....mine are still okay - for the moment. PM me if you need Manual Info :D BTW - We are planning on visiting again Oct 2005 Quote Link to comment Share on other sites More sharing options...
jzz30 Posted December 29, 2004 Share Posted December 29, 2004 yea the roads in hawaii are really bad in some places and hard rain doesnt help the road either, it seems to just wash away things... k9crew, if you need a mechanic to do your stuff i can take a look;) Quote Link to comment Share on other sites More sharing options...
K9crew Posted December 30, 2004 Author Share Posted December 30, 2004 99, Good to be back!! Thanks for the offer of info in the manual and see you in September if I'm still here. jzz30, Thanks for the offer and I'll let you know if I need professional help!! Quote Link to comment Share on other sites More sharing options...
K9crew Posted January 8, 2005 Author Share Posted January 8, 2005 Well, I replaced all four rotors and front and rear brake pads on 01/01/05. I remembered to clamp off the brake lines and loosen the bleeder screw when pushing the pistons back into the caliper so as to prevent debris from working its way back towards the master cylinder. The rear pads were almost completely worn down ... maybe 10% left (they were the original pads). The front pads had about 40% left. I partially flushed the brake fluid with Valvoline Syntec brake fluid and bled all four lines. I didn't bleed the ABS though and plan to do it this weekend. I checked the suspension out fairly thoroughly along with the hubs and decided that I only need to change the "cushions" on the two suspension arms that connect the lower control arm to the unibody (run from lower control arm forward). The end that connects to the LCA has two studs and the other end has a large bushing/cushion connection. I ordered new cushions for $38.76 each from my local Lexus dealer. Once I replace those I should no longer have the thumping sound when I hit a pothole or speed bump ... we'll see. The brakes are WAY better now. I have Centric cross-drilled/slotted rotors with AXXIS pads (formerly Repco Metal Master). They're a bit slick when cold but once warm they're excellent. Also, I reassembled the shims on all pads as per the manual and I have no brake noise, no squealing, no rattling, just quiet and effective braking. :) Quote Link to comment Share on other sites More sharing options...
bicol-ini Posted January 8, 2005 Share Posted January 8, 2005 hello, good job, whats the part number for the front strut rod bushing, any pix of the old one, see how deteriorated they are,? if you got from a lexus dealer then part number should be in the reciept Quote Link to comment Share on other sites More sharing options...
highlander Posted January 8, 2005 Share Posted January 8, 2005 I would like to know the part number for that bushing really... as i wasted 70 on poly bushings for it. Quote Link to comment Share on other sites More sharing options...
bicol-ini Posted January 8, 2005 Share Posted January 8, 2005 hello, highlander where did you buy yours, whats the brand who makes them and their part number, Quote Link to comment Share on other sites More sharing options...
highlander Posted January 9, 2005 Share Posted January 9, 2005 lpdauto@charter.net contact him.. very quick to ship my stuff... let him know i sent you please. Quote Link to comment Share on other sites More sharing options...
K9crew Posted January 10, 2005 Author Share Posted January 10, 2005 The part number on my receipt is 48674-40051 and I ordered two of them since it's the same part for the left and right side. I plan on replacing the cushions (that's what the dealership calls them) on 01/17/05 or the weekend before and I'll take photos of the old and new cushions. My LS is a '99 model so the part number may be different for your vehicle. :) Quote Link to comment Share on other sites More sharing options...
99lsguy Posted January 10, 2005 Share Posted January 10, 2005 The part number on my receipt is 48674-40051 and I ordered two of them since it's the same part for the left and right side. I plan on replacing the cushions (that's what the dealership calls them) on 01/17/05 or the weekend before and I'll take photos of the old and new cushions. My LS is a '99 model so the part number may be different for your vehicle.:) ← excellent K9!! take a few photos if possible ........I"m sure I'll be doing this eventually....... <_< Quote Link to comment Share on other sites More sharing options...
VBdenny Posted January 10, 2005 Share Posted January 10, 2005 Very interesting. The local Lexus dealer here told me the "cushions" are not replaceable and that the whole unit needed to be replaced. Cost me about $600 to have Lexus do that. Of course that was when I first bought the car and didn't know anything about fixing them. You all have saved me quite a bit of money the last few years. Quote Link to comment Share on other sites More sharing options...
bicol-ini Posted January 11, 2005 Share Posted January 11, 2005 hello, yes the front strut rod bushings are available as a separate item with the part number 48674-40051, and sells for 40 bucks more or less at lexus and is also used by toyota cars same part number since they use universal numbering system, but for less 30 bucks, Quote Link to comment Share on other sites More sharing options...
bicol-ini Posted January 11, 2005 Share Posted January 11, 2005 hello, k9crew has a 99ls so for the cushion strut bar front part #48674-40051 BUT for a 96 its part# 48674-50051, this will be the correct part# for the cushion strut bar for 95-97 ls Quote Link to comment Share on other sites More sharing options...
K9crew Posted January 13, 2005 Author Share Posted January 13, 2005 Hey, the Lexus dealer called to tell me that the strut bar cushions have arrived and 99lsguy very kindly helped me out with some relevant information from the factory repair manual so I'm all set for this weekend. I'll try to take some photos and provide a HOW TO of sorts. I sure hope this doesn't turn out to be a "goat roping"!! I'm quietly optimistic that my car will be knock-free after this little project. :) Quote Link to comment Share on other sites More sharing options...
