I was hoping to install my own TPS sensor, assuming it was not going to be any more difficult than on my other Fuel Injected rides.
I have the sensor now, but I've been informed that the Lexus uses a "throttle blade angle" test tool or something like that instead of setting the TPS via a digital multimeter and specific voltages.
Can anyone (guytelefunken?) shed any light on this, or as to whether I will be able to even do this myself? My dealer wants $115.
Thanks!
Why don't you take that $115 and buy a service manual, since you like to do things yourself, it will prove invaluable and save you lots of money in the long run. <_<
The part cost is about. $80.00. If it were me, I'd let the dealer do it if I didn't have the tools. You need a Lexus Handheld Tester or any OBDII compliant scantool that can display throttle position DATA as a %.
GS4xx_TPS.pdf
Are you suurrre that I don't have one? B)
I would *absolutely* do that, but at the moment, I was concerned about the extra cost of a special tool that I may never use again. :)
There are no voltages listed in the service manual.
Incidentally, I do know someone with an OBDII scan-tool. I will check into whether it displays throttle position as a percentage. If it doesn't, I'll hit the dealer.
(or see how much a scan tool costs!)
Thanks a bunch guys, even you Turbo GS300. <_<
Scan tool that plugs into a PC will cost under $100 so works out cheaper and will save you money in the future. If you don't have a PC (ideally a notebook so you can carry it to the vehicle) then stand alone units are available but will cost you much more.
This is the one I use and gives you the throttle % required to adjust the TPS:
http://www.obddiagnostics.com/
