Power Steering Fluid
I think the guy i bought the car from used regular power steering fluid because i found a bottle under the seat . I poured dextron3 auto transmission fluid on top of that. Is this a cause for concearn possibly? What would you do in this situation?
Also i was wondering where is the cheapest place to get headlight lenses or the whole assembly online.
'93 sc400
actually it is not hard
just disconnect the return line from the resvoiur and start the engine to lush it out
then fill with proper fluid ,you may need to repeat if it has been in their for a while,but considering it was kept in the car it probably has a leaking pump right onto your alternator,very common problem
