surge Posted December 13, 2004 Share Posted December 13, 2004 My Check Engine light came on today so I hooked up my PC and it read: --P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control --P1133 Sensor Circuit Slow Response (Bank 1 Sensor 1) --P1135 Sensor Heater Circuit (Bank 1 Sensor 1) I cleared the Check Engine light and about a few minutes later the following came up: --P1130 O2 Sensor Circuit (Bank 1 Sensor 1) I reset it again and a few minutes later the P1130 came back on. In any case, it seems that the O2 sensor in Bank 1 Sensor 1 is bad. Does anyone know the part # for this? and where is a good place to get this. I found a few different O2 sensors. on Advance Auto Parts website: Which one do I need? is Bank 1 Sensor 1 the Downstream or Upstream? The Bosch is twice the money and has a 1 year Warranty and the Beck/Arnley has a Lifetime warranty for half the price. Bosch 13338 OE Type; 4 Wire; Heated; Downstream Sensor; Check/Replace Interval 100 K Miles 1 Year Replacement Warranty Ships in 1 day Weight: 0.3 lbs. $222.88 Bosch 13333 OE Type; 4 Wire; Wideband; Upstream Sensor; Two required; Check/Replace Interval 100 K Miles 1 Year Replacement Warranty Ships in 1 day Weight: 0.3 lbs. $328.88 NAPA has this one for $200 Beck/Arnley 1568401 See image and details for this item Repl Type Oxygen Sensor: Flange Type Lifetime Limited Warranty Ships in 1 day Weight: 0.3 lbs. $118.88 Beck/Arnley 1568400 See image and details for this item Univ Type Oxygen Sensor: Screw Type Lifetime Limited Warranty Ships in 1 day Weight: 4.1 lbs. $93.48 thanks Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 13, 2004 Share Posted December 13, 2004 sensor 1 bank 1 is the one at the back of the engine bay on the exhaust manifold because you get a code it does no mean it is bad get a motorvac to remove the carbon first Quote Link to comment Share on other sites More sharing options...
Geno Posted December 13, 2004 Share Posted December 13, 2004 search this forum for the following code P1133 and you will find a wealth of good posts on this topic. I found my bank one on ebay for cheap. I would not suggest the aftermarket brands as the wiring does not match up. https://www.automedicsupply.com/index.php?P...61f7aeadb5f1b1d http://www.lexusownersclub.co.uk/knowledge..._v2&id=152&c=11 go to oxygensensors.com http://www.napaonline.com/cgi-bin/ncommerc...mgrpid=83947908 Good Luck! Quote Link to comment Share on other sites More sharing options...
surge Posted December 14, 2004 Author Share Posted December 14, 2004 So this is the upstream, before the cat..right? oxygensensors.com says 2 are required. which is considered sensor 1. does anyone have any pics? thanks. search this forum for the following code P1133 and you will find a wealth of good posts on this topic. I found my bank one on ebay for cheap. I would not suggest the aftermarket brands as the wiring does not match up. https://www.automedicsupply.com/index.php?P...61f7aeadb5f1b1d http://www.lexusownersclub.co.uk/knowledge..._v2&id=152&c=11 go to oxygensensors.com http://www.napaonline.com/cgi-bin/ncommerc...mgrpid=83947908 Good Luck! ← Quote Link to comment Share on other sites More sharing options...
Geno Posted December 14, 2004 Share Posted December 14, 2004 Bank 1 is the one before the catalytic converter and underneath the vehicle. The bank 2 sensor is in front of the engine and can be seen from underneath the hood. I am almost certain both sensors are interchangeable. Your problem is the one underneath the vehicle. I am not certain if the sensor underneath the hood is called the bank 2. Geno K Quote Link to comment Share on other sites More sharing options...
Geno Posted December 14, 2004 Share Posted December 14, 2004 Bank 1 is the one before the catalytic converter and underneath the vehicle. The bank 2 sensor is in front of the engine and can be seen from underneath the hood. I am almost certain both sensors are interchangeable. Your problem is the one underneath the vehicle. I am not certain if the sensor underneath the hood is called the bank 2. Geno K ← I only needed the bank one to solve my problem. I am sure they want you to buy them both. Quote Link to comment Share on other sites More sharing options...
Geno Posted December 14, 2004 Share Posted December 14, 2004 Go to EBAY motors and look up this item #7933252847 email the guy with the name ironman. he sold me a original toyota sensor that fit my lexus. he had more of them I think. Quote Link to comment Share on other sites More sharing options...
