lexus400 Posted December 9, 2004 Share Posted December 9, 2004 I'm doing some work on my mother in laws ES and she has been having a problem where if the car sits for a while (multiple days) the car won't start because it sounds like the battery is dead. The battery is a 3 year old Diehard and it tests ok along with the alternator/charging system. Yesterday when she tried to start it all she heard was "click" a few times (like a dead battery). She kept trying and all of a sudden it just started right up. Now I'm suspicious of the starter/solenoid. When it has been dead, I've jumped it myself and it's started. I've tested the battery and charging system myself and it all checks out. Any ideas ? Is the starter or solenoid a likely candidate ? Bob Quote Link to comment Share on other sites More sharing options...
lexus400 Posted December 9, 2004 Author Share Posted December 9, 2004 Ok, it just happened to me first hand. Car sat overnight in my garage and when I tried to start it, I just got clicking. I grabbed my batt/alt tester and sure enough the battery was low - not dead but low. I had my wife try it a few more times and on the fourth try it started right up. I tested the battery again - GOOD ! This is the exact same thing that happened to her the other day. I just started it 6 times in a row and it's fine. I'm stumped. Any ideas appreciated ! Bob Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 9, 2004 Share Posted December 9, 2004 what year car? I would suggest to change the battery cables and terminals as well as the alternator isnlt being charged properly Quote Link to comment Share on other sites More sharing options...
lexus400 Posted December 10, 2004 Author Share Posted December 10, 2004 It's a '96 and I changed the starter/solenoid which came as one unit. Seems to have fixed the problem. I'm pretty sure the solenoid was getting hung up which accounted for the clicking but the battery charge was ok. Bob Quote Link to comment Share on other sites More sharing options...
mxl4729 Posted December 10, 2004 Share Posted December 10, 2004 It's a '96 and I changed the starter/solenoid which came as one unit. Seems to have fixed the problem. I'm pretty sure the solenoid was getting hung up which accounted for the clicking but the battery charge was ok.Bob ← normally when the solenoid clicks it is ok. but many times the brushes that commutate the motor could land on a dead spot and you will get a problem like you are getting. fix is to change the stator which it seams u have done good job Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 11, 2004 Share Posted December 11, 2004 i would agree the solenoid is in need of fixing but not replacment it is caused by carbon tracking on the copper terminals which is caused by an insufficent vdc to activate causing arcing and leaving carbon tracking which gets progessivly worse like compounding interest payments you need to find why you had a low vdc problem which is more than liekly bad wires or you will end up replacing batteries and solenoids more than needed, I have a 94 and never have replaced my starter, then again i don;t know many people who have changed theirs ever Quote Link to comment Share on other sites More sharing options...
