92LexES Posted December 5, 2004 Posted December 5, 2004 Hey sup, i am a current 3 year owner of my 92 es300, i had gone into a accident with my front bumber recently, The front support or frame has been pushed in to the right a litter enough to break my headlights out of place, my hood was also busted because of the push in, I was wonderiin how much would it cost to pull my frame back together. I am sure that someone had gone thru this before where u hit into someone's back and cause your hood to pop up and causing your front bumper to get pust in a little ruining the front frame. the front bumper looks like nothing happen but the front frame has been push in at a angle and so it causes the right headlight to be not in place. Money is not an issue but just wanted a more estimate to how much it would cost to repair the frame in the front... thanks for the time..
ArmyofOne Posted December 6, 2004 Posted December 6, 2004 Hey sup, i am a current 3 year owner of my 92 es300, i had gone into a accident with my front bumber recently, The front support or frame has been pushed in to the right a litter enough to break my headlights out of place, my hood was also busted because of the push in, I was wonderiin how much would it cost to pull my frame back together. I am sure that someone had gone thru this before where u hit into someone's back and cause your hood to pop up and causing your front bumper to get pust in a little ruining the front frame. the front bumper looks like nothing happen but the front frame has been push in at a angle and so it causes the right headlight to be not in place. Money is not an issue but just wanted a more estimate to how much it would cost to repair the frame in the front... thanks for the time.. ← current industry standard is $975 per inch of straightening. it has to be straightened, then sanded, primed and painted to protect from elements. that was going to cost me $850 JUST to repair the front cor support, because it bent the "frame rails" in about 3/4". and thats only that price cause i knwo someone in the business.
Lexusfreak Posted December 6, 2004 Posted December 6, 2004 Hey sup, i am a current 3 year owner of my 92 es300, i had gone into a accident with my front bumber recently, The front support or frame has been pushed in to the right a litter enough to break my headlights out of place, my hood was also busted because of the push in, I was wonderiin how much would it cost to pull my frame back together. I am sure that someone had gone thru this before where u hit into someone's back and cause your hood to pop up and causing your front bumper to get pust in a little ruining the front frame. the front bumper looks like nothing happen but the front frame has been push in at a angle and so it causes the right headlight to be not in place. Money is not an issue but just wanted a more estimate to how much it would cost to repair the frame in the front... thanks for the time.. ← current industry standard is $975 per inch of straightening. it has to be straightened, then sanded, primed and painted to protect from elements. that was going to cost me $850 JUST to repair the front cor support, because it bent the "frame rails" in about 3/4". and thats only that price cause i knwo someone in the business. ← Don't forget to remove your cell phone before getting the work done lol. j/k B) ;)
ArmyofOne Posted December 7, 2004 Posted December 7, 2004 Hey sup, i am a current 3 year owner of my 92 es300, i had gone into a accident with my front bumber recently, The front support or frame has been pushed in to the right a litter enough to break my headlights out of place, my hood was also busted because of the push in, I was wonderiin how much would it cost to pull my frame back together. I am sure that someone had gone thru this before where u hit into someone's back and cause your hood to pop up and causing your front bumper to get pust in a little ruining the front frame. the front bumper looks like nothing happen but the front frame has been push in at a angle and so it causes the right headlight to be not in place. Money is not an issue but just wanted a more estimate to how much it would cost to repair the frame in the front... thanks for the time.. ← current industry standard is $975 per inch of straightening. it has to be straightened, then sanded, primed and painted to protect from elements. that was going to cost me $850 JUST to repair the front cor support, because it bent the "frame rails" in about 3/4". and thats only that price cause i knwo someone in the business. ← Don't forget to remove your cell phone before getting the work done lol. j/k B) ;) ← ahh yes, i was waiting on a call frm work. and thats my house phone...1 of 4 (big house) B)
Lex3486 Posted December 7, 2004 Posted December 7, 2004 I hope that you removed the cover on that timing belt. I mean, I know that Ford probably doesn't make the BEST car around, but not even covering the timing belt?!
ArmyofOne Posted December 7, 2004 Posted December 7, 2004 I hope that you removed the cover on that timing belt. I mean, I know that Ford probably doesn't make the BEST car around, but not even covering the timing belt?! ← i removed the top cover. i liked it off. and before you say anything, i had had it removed for over 200,000 miles. changed the Timing belts at 65,000 mile intervals since car was new. :D
