ec437 Posted November 30, 2004 Share Posted November 30, 2004 I'm assuming so, this has been the way it has been with my BMW's. Actually the BMW's had a flat crossmember so I could jack there as well, not so with this car... I'm aware that I have to place the jack on part of the frame, henceforth why I'm assuming the framerails to be fine :D Thanks. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted November 30, 2004 Share Posted November 30, 2004 frame rails always bend under weight , i wouldn;t , but i can usually find another spot like the cross member or suspension arms Quote Link to comment Share on other sites More sharing options...
ec437 Posted November 30, 2004 Author Share Posted November 30, 2004 frame rails always bend under weight , i wouldn;t , but i can usually find another spot like the cross member or suspension arms ← meh... too late. I didn't have to jack it all the way off of the ground though, and put jackstands under the stock jack locations as soon as it got high enough. Car still handles like a friggin' 40 foot schooner in the twisties, but high speed braking performance has been much improved. Some nimrod at a tire shop had torqued my lugs to about 250 lb/ft while under charge of the previous owner. And he didn't even torque them wrong consistently! varied about 40 lb/ft each way... damn fools with their impact wrenches...:chairshot: Oh by the way, I won't have my jacking point problem when I have a garage of my own. I'll be putting a lift in :D And wouldn't jacking on the crossmember stress mostly the motor mounts? That can't be good for them. Quote Link to comment Share on other sites More sharing options...
wwest Posted November 30, 2004 Share Posted November 30, 2004 I always use the factory designated jacking points but use a wood block between the floor jack and.... Quote Link to comment Share on other sites More sharing options...
bartkat Posted November 30, 2004 Share Posted November 30, 2004 frame rails always bend under weight , i wouldn;t , but i can usually find another spot like the cross member or suspension arms ← meh... too late. I didn't have to jack it all the way off of the ground though, and put jackstands under the stock jack locations as soon as it got high enough. Car still handles like a friggin' 40 foot schooner in the twisties, but high speed braking performance has been much improved. Some nimrod at a tire shop had torqued my lugs to about 250 lb/ft while under charge of the previous owner. And he didn't even torque them wrong consistently! varied about 40 lb/ft each way... damn fools with their impact wrenches...:chairshot: Oh by the way, I won't have my jacking point problem when I have a garage of my own. I'll be putting a lift in :D And wouldn't jacking on the crossmember stress mostly the motor mounts? That can't be good for them. ← It's ok to jack it that way and put the jack stands under the notched out places that are there for the regular jack. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted November 30, 2004 Share Posted November 30, 2004 using an oem jack on the rails is perfect as it is notched in the head to hodl tight it would work best if you can make a notched base for your jack to push up on Quote Link to comment Share on other sites More sharing options...
ec437 Posted November 30, 2004 Author Share Posted November 30, 2004 using an oem jack on the rails is perfect as it is notched in the head to hodl tightit would work best if you can make a notched base for your jack to push up on ← I'll make one of those by molding a hockey puck to the lifting surface of the jack. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 1, 2004 Share Posted December 1, 2004 now that is an amazing thought since their is no hockey now anyway lmao Quote Link to comment Share on other sites More sharing options...
lex4me Posted December 3, 2004 Share Posted December 3, 2004 I took a 2x4, cut it so that it was square, put a notch in it with a dado blade for the frame rail, and then contoured the back to roughly match the curvature of my floor jack. Works great! B) Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 3, 2004 Share Posted December 3, 2004 wood always splinters under weight too much for me to ever use it for holding something especially with me under it Quote Link to comment Share on other sites More sharing options...
lex4me Posted December 6, 2004 Share Posted December 6, 2004 I expected it to splinter or out right crack in two pieces as well, but it never has given any trouble across the several dozen times I have used it. If it did crack one day, the jack bowl (or whatever that thing is called) would catch the car within 3/4 of an inch anyway, so I have never been worried about it. I never, ever get under the car with just a jack supporting it anyway - I put my trust in safety stands. Quote Link to comment Share on other sites More sharing options...
