Moon Roof
I just bought a used 1996 ES300 and can hear a somewhat annoying air leak above my head when the moon roof cover is pulled back. When I slide the cover closed, I really don't hear it much. So before someone says to just keep the cover closed, can a Lexus Service Tech, or anyone for that matter, effectively address this problem with a better seal?....Thanks...
since i cnnot see the seal it is hard to say wether it is the seal or the roof needs to be adjusted in position with shims
do you have a cell phone antenna?
as this can sometimes cause excess noise also
one option is to use silicone spray on the seal to help the seal .........seal
also use the spray on all the windows and doors edges and don't forget the trunk
as any air to get out has to get in first
seal as many places as possible and you will reduce wind noise
also the doors may be leaking on the windowsedges if they are closed frequently by passanger using the window instead of the door
and since there is no frame it goes out of alignment and leaks air
usually and not water
any brand they all are pretty much the same
pep boys and napa any real auto parts seller
i don't think walmart but i haven't looked lately in the auto aisle in a U.S. stoer for silicone spray
lol
later
