RobNAUTICA Posted November 16, 2004 Posted November 16, 2004 i would love to get a remote starter on my 99 rx300 but someone told me that remote starters are bad for your Starters (and i'm not exactly happy with the idea of buying an expensive replacement part...) anybody know the truth?
zube Posted December 8, 2004 Posted December 8, 2004 IF A REMOTE START IS PROPERLY INSTALLED IT STARTS THE CAR THE CAR BETTER THAN YOU. ILL EXPLAIN WHEN YOU START THE CAR YOU CAN OVER CRANK THE CAR WHICH IS BAD FOR THE STARTER. WHEN THE REMOTE START DOES IT IT HAS A WIRE HOOKED UP TO THE TACH WIRE SO IT KNOWS AS SOON AS THE ENGINE START IT STOPS CRANKING.
white lexus Posted November 18, 2007 Posted November 18, 2007 IF A REMOTE START IS PROPERLY INSTALLED IT STARTS THE CAR THE CAR BETTER THAN YOU. ILL EXPLAIN WHEN YOU START THE CAR YOU CAN OVER CRANK THE CAR WHICH IS BAD FOR THE STARTER. WHEN THE REMOTE START DOES IT IT HAS A WIRE HOOKED UP TO THE TACH WIRE SO IT KNOWS AS SOON AS THE ENGINE START IT STOPS CRANKING. Do you recommend a specific brand/model of remote starter?? I want one for my RX300.
djspawn00 Posted November 18, 2007 Posted November 18, 2007 I've never had any issues with systems from Prestige.
