babyduke Posted Sunday at 09:45 PM Share Posted Sunday at 09:45 PM 2009 ES350 Sunglasses compartment suddenly wouldn't open but I was able to pop it out. How do I put it back in? I don't care if it won't work. I just want it there. Quote Link to comment Share on other sites More sharing options...
RX400h Posted yesterday at 01:43 AM Share Posted yesterday at 01:43 AM On 9/15/2024 at 2:45 PM, babyduke said: 2009 ES350 Sunglasses compartment suddenly wouldn't open but I was able to pop it out. How do I put it back in? I don't care if it won't work. I just want it there. Quote Copilot Sent by Copilot: Got it! To put the sunglasses compartment back in your 2009 Lexus ES350, follow these steps: Align the Compartment: Position the compartment so that the hinges are aligned with the slots in the overhead console. Insert the Hinges: Carefully insert the hinges into the slots. You might need to gently push or wiggle them to get them seated properly. Secure the Compartment: Once the hinges are in place, push the compartment up until it clicks into position. This might require a bit of force, but be gentle to avoid breaking anything. If the compartment doesn’t stay closed or is loose, you might need to use a bit of adhesive or tape to keep it in place since you mentioned you don’t care if it works. 1 Quote Link to comment Share on other sites More sharing options...
babyduke Posted yesterday at 01:58 PM Author Share Posted yesterday at 01:58 PM 12 hours ago, RX400h said: Thank you! 1 Quote Link to comment Share on other sites More sharing options...
