Erick Strong 1 Posted May 29 Share Posted May 29 I to have the rear camera indicator light flashing yellow, and will try turning the steering wheel to the lock position left and right praying that this will resolve the situation Both lights came on after the car struggled to start. Quote Link to comment Share on other sites More sharing options...
Erick Strong 1 Posted May 29 Author Share Posted May 29 I also have the parking support brake system [PKSB] light flashing yellow indicating off, this along with the [RCTA] light both came on after the car struggled to start. Quote Link to comment Share on other sites More sharing options...
Erick Strong 1 Posted May 29 Author Share Posted May 29 My navigation map only displays the large city of origin, it as stopped showing the local towns in which I drive thru. Quote Link to comment Share on other sites More sharing options...
RX400h Posted May 29 Share Posted May 29 15 hours ago, Erick Strong 1 said: I to have the rear camera indicator light flashing yellow, and will try turning the steering wheel to the lock position left and right praying that this will resolve the situation Both lights came on after the car struggled to start. Quote It seems like you’re experiencing two separate issues with your 2018 Lexus LS 500: a flashing yellow rear camera indicator light and difficulty starting the car. Rear Camera Indicator Light Flashing Yellow This issue is often reported by Lexus LS 500 owners after a battery change. The Rear Camera Detection (RCD) light starts flashing, and turning the steering wheel left and right on level ground, as suggested in the manual, does not always resolve the issue. Some owners have found success by turning the wheel all the way to the left and then all the way to the right. If this doesn’t work, it’s recommended to consult with a professional as the Lexus dealership may need to reset the system. Car Struggling to Start The most common causes for a car struggling to start are a dead or weak battery, corrosion on battery terminals, or a dead key fob battery. If the battery is weak, the car may take longer to start or may not start at all. It’s important to check the battery terminals and cable connections for corrosion and clean them if necessary. If these steps don’t resolve the issue, it would be best to have the car inspected by a professional. Remember, while these are common solutions, they might not apply to your specific situation. Always consult with a professional if you’re unsure. Quote Link to comment Share on other sites More sharing options...
RX400h Posted May 29 Share Posted May 29 15 hours ago, Erick Strong 1 said: I also have the parking support brake system [PKSB] light flashing yellow indicating off, this along with the [RCTA] light both came on after the car struggled to start. Quote The flashing yellow lights for the Parking Support Brake system (PKSB) and Rear Cross Traffic Alert (RCTA) on your 2018 Lexus LS 500 could be indicative of a system error or malfunction. The PKSB system is designed to help prevent or reduce damage by applying the brakes in certain situations where the vehicle gets too close to an object. It operates when the shift lever is in a position other than P or R and the vehicle speed is approximately 10 km/h (6 mph) or less. RCTA is a system that assists the driver when backing up by alerting them to vehicles approaching from the right or left at the rear of the vehicle. If these lights came on after the car struggled to start, it could be related to a weak battery. A weak battery can sometimes cause the vehicle’s computer to trigger warning lights. It’s also possible that there could be a software issue that needs to be addressed. There was a special service campaign for certain 2018 Lexus models, including the LS 500, to reprogram the Intelligent Clearance Sonar (ICS) system. I would recommend taking your vehicle to a Lexus dealership or a qualified mechanic for a proper diagnosis. They have the necessary tools and expertise to accurately identify and fix the issue. Please remember that continuing to drive with these warning lights on could potentially lead to more serious issues. Safety should always be your top priority. Quote Link to comment Share on other sites More sharing options...
RX400h Posted May 29 Share Posted May 29 15 hours ago, Erick Strong 1 said: My navigation map only displays the large city of origin, it as stopped showing the local towns in which I drive thru. Quote It’s possible that the issue could be related to the map settings or it might need an update. Here are a few steps you can try: Check the Map Settings: Ensure that the map settings are correctly configured to display local towns. You can usually find these settings in the navigation menu. Update the Maps: The maps on the Lexus Navigation system can be updated periodically using downloadable updates. This ensures that you always have the latest road and route information. You might need a blank, formatted 4GB USB memory stick and an internet-connected computer for this process. Reset the System: If the above steps don’t work, you might need to reset the navigation system. Please refer to your vehicle’s manual or contact your local Lexus dealer for specific instructions on how to do this. If none of these steps resolve the issue, I recommend taking your vehicle to a Lexus dealership for further assistance. They have specialized tools and expertise to diagnose and fix the issue. Quote Link to comment Share on other sites More sharing options...
