Hi a newbie to this Forum, I'm confused in regards to a timing belt or chain on a 2008 RX350, I've always believed  that the 2007 and above RX with the 3.5 L engine has a timing chain
yet on this Forum someone stated that it has a belt, perhaps the belt is exclusive to the RX400H and not the regular RX350 ?
You are correct. timing chain on 2007 & up 3.5 engines . Hybrids ???
The RX400h uses a timing belt because a belt does last longer in a vehicle that is not running for some or much of the time, depending upon traffic conditions and locations.
 Also, belts are typically quieter than chains.
  • 9 months later...
Yes all the 400h from 06 to 08 have the 3.3 engine that carried over from the 330 which has the timing belt
  • 2 months later...
My 07 RX400h has about 86,000 miles and hasn't had the timing belt changed yet... How concerned should I be?
