Paul L 55 Posted April 23, 2023 Posted April 23, 2023 I recently helped my wife get her deceased parent's 2011 ES (13000 miles) to a dealer after it sat for three years without being started or moved. I did some reading on the internet about the multiple steps and precautions necessary before attempting to start a car in this condition, including lubricating the cylinders with "fogging oil." The dealer's maintenance staff ignored my concerns and after simply turning over the engine for a bit to "pump oil into the top of the engine," proceeded to start it up. When I questioned why they had taken that approach, I was told that the engine tolerance are so tight and the new metals used in these engines, that this procedure was sufficient and the engine would not be damaged. I asked if Lexus had a written protocol for such circumstance and was no. Can anyone comment on this scenario? Am I being overly concerned with the potential for damage to the engine and were the dealer's procedures appropriate? Thanks!
RX400h Posted April 24, 2023 Posted April 24, 2023 I have a few questions about the procedure: 1. Did they drain and fill all fluids, including the gasoline? 2. Did they check and replace, if necessary, all air filters? 3. Did they replace the battery? If they did, I don't think that any damage had occurred when they started the engine. 1
Bykfixer Posted April 24, 2023 Posted April 24, 2023 It's normal with modern engines with that many miles on it to bump the starter a few times to pump oil into the pistons. No reason to be alarmed. Brand new engine? That's a no no. If the gasoline had stabilizer in it just add fresh fuel. If it didn't or you don't know it would be best to remove the old fuel, but not required.
